REMOVAL
Release door latch and open door.
Lower door glass.
Remove window regulator crank, if so equipped (Window Crank).
Remove screw from inside arm rest pull cup (Front Door Trim).
Remove screw from behind inside latch release handle.
Disengage push-in fasteners attaching trim to door panel around perimeter of trim panel.
Tilt trim panel outward to clear locator pins on backside of trim panel.
Disconnect trim panel from retainer channel in inner belt weatherstrip at top of door by lifting while gently jiggling.
Move trim panel away from door and disengage clip attaching latch rod to handle.
Remove latch rod from handle.
CAUTION: Do not allow door trim panel to hang by the wire connector or wiring.
Disconnect wire connector from power door lock switch, mirror switch, and power window switch if so equipped.
Remove trim panel from door.
