1 - 11 of 11 Posts
When I got under the rear end of the car to replace the exhaust hanger a while back, I noticed that the two black arms on the rear left, did not match the two black arms on the rear right. One of the arms on the right rear seems to be on backwards. The parts I'm talking about are powder-coated black and bolt to the center of the frame in the rear of the car and fasten onto each wheel's suspension.
I'll try to take a picture sometime to show you what I mean.
Anyone?
you are talking about the control arms?
your car is fine dude i got to check another SRT4 see since the control arms are the same length etc. DCX used the same setup for both sides except in reverse get me? so for the rear control arms there are only 2 part numbers needed. Thanks ...NEEEEXXXT! :roll: :lol:
It's not right, man. The part is the right part, it's just put on backwards! If you look at the ends of the arms, there are bushings on them. The arms are NOT symmetric. The bushing hang out one side more than the other... I'll just have to try to take a pic and post it...
-Sam
Super Moderator
Black ‘21 Mach 1 Mustang Tremec 6-Speed/Recaros
QwikSC2 said:
See how the right side is backwards of the left?
So the production line worker was a little Dyslexic. Or maybe it was a Dyslexic Robot. :idea:
I see no logical explanation for it. I think you would want the stronger( fatter ) side closer to the wheel, where there is more stress.
I'll take a peek at mine tomorrow.
Cali
you guys are all freaking out for nuthing...lmao its called cost cutting :wink:
Discussion Starter · #10 ·
Once again, it is the CORRECT part, it's just mounted backwards! If you were to take that one off and flip it, it would be correct. If the part were symmetrical it wouldn't worry me, but it's not. The bushings are kinda offset at the end.
-Sam
Sam, I have 1, and my bro just bought 1, looking at both they are both the same, left side facing out, right side facing in.
1 - 11 of 11 Posts
