ok the pictures will follow but to install the passenger side mounts, which BTW are very simple you must do the following:
-Raise car with a floor jack on each side and place a jack stand ON each frame rail itself.
-The car should now have its front end off the ground and you may proceed to remove the passenger side wheel.
-After you have done this then you need a 10mm to remove 2 bolts that hold the fender liner to the frame rail.
-They are tucked away so shine some light up in there and you'll see them.
-Once those two are out then you have two plastic clips that hold it to the bracket that holds the windshield washer reservoir to remove.
-One last 10mm bolt on the front end will set the splash guard free.
-Now you'll have full view and access to the lower mount and with a deep socket 18mm remove the center screw to the mount end closest to the front of the car.
-With a deep socket 15mm (if im not mistaken) remove the screw that holds the mount onto the frame.
-Remove the lower mount and proceed backward to the previous steps for reassembling the lower portion of the vehicle.
-After you bring the car off the jack stands and jack you may now proceed to the easiest mount the top mount.
-The install on this mount is sooo simple that it needs no instructing but that of making sure you use the correct tools. Reason being that the center screw that connects mount to the motor is not easily accessed due to AC lines.
Tranny mount (if ordered as 3 mount set) oh the joys.....
Well i was forwarned about this task and wish this upon no one to have to do this...even if its for free like me:
-Start (assuming the car is already on jackstands) by removing the driver's side wheel for access to mount ceneterbolt access point and later for other purposes.
-If you look in the fenderwell there is a access point to the tranny mount centerbolt, pop the cap off carefully with a flathead
-Remove the Airbox, battery and battery tray
-use a jack (with a small piece of plywood on it), place under tranny and jack tranny up a bit.
-The bracket that holds the battery tray is your friend but will quickly become your bitch.
-See the tranny mount has 3 bolts that hold it to the tranny which are all almost impossible to reach from the top and dont mention the bottom. Well 2 arent and the 3rd is. Then you have the centerbolt
-you may now with an 18mm deep socket reach into access point and unscrew the centerbolt to the tranny mount. Loosen it but dont pull it out
-Now the bracket (holds the battery tray), what we did was we unbolted the 3 easily accessible bolts to the bracket and then there is this very pesky plastic clip holding up some wiring that you'll need to pull out from the inside of the frame rail to free the bracket.
- You can either remove or lift the braket up so that when you have removed the 3 mounting bolts all you have to do is pull the centerbolt.
-remove 3 mounting bolts and centerbolt
-Once that is complete you can lower the tranny slowly (I MEAN SLOWLY!) to the point that you can reach all three mounting bolts on the tranny that hold the mount to the tranny.
-At the same point you can remove the last bolt (its buried on the bottom of the bracket inside the frame rail) dont forget to look under the fusebox there is a nut that holds the bracket there too.
- Remove tranny mount and replace
-It is a whole lot easier to mount all the screws to the bracket back on first then place the tranny mount so that when the bracket is set the mount can move and be positioned.
- place the 3 bolts that hold mount to tranny in place and tighten
- This is the trickiest part, with the jack you must now raise and with the naked eye line up the centerbolt hole
-once it is lined up proceed to insert the centerbolt and tighten.
- You are almost done now you just need to put both wheels back on (if you havent already put one back on).
- Place airbox, battery tray and battery back in their respective places.
- make sure that all connections and fitting are correctly fastened
- make sure you leave no tools on the car
- make sure you jack the car up, remove the jack stands and lower it.
-Done , the tranny mount is the most time comsuming so i suggest you start there.
Any questions?
