Defi gauges and accessories, ALMOST ALL IN STOCK!
FREE SHIPPING on any order over $100 too!
you can paypal [email protected] to order or visit the store at the link below:
click here to check out ALL our Defi products (ALMOST ALL IN STOCK)
VSD system HUD (heads-up-display)
Defi DIN Gauge (3-gauge)
Defi D-Gauge
Defi Link Gauge
Defi Link BF Gauge
Defi Link BF AMBER Gauge
Defi (3-Gauges) DIN Gauge BLACK $495.00
Defi (3-Gauges) DIN Gauge WHITE $495.00
Defi D-Gauge 115mm Tachometer Black $235.00
Defi D-Gauge 115mm Tachometer White $235.00
Defi D-Gauge 2-1/16 inch Air/Fuel Gauge Black $120.00
Defi D-Gauge 2-1/16 inch Air/Fuel Gauge White $120.00
Defi D-Gauge 2-1/16 inch Boost Gauge Black $120.00
Defi D-Gauge 2-1/16 inch Boost Gauge White $120.00
Defi D-Gauge 2-1/16 inch EGT Gauge Black $190.00
Defi D-Gauge 2-1/16 inch EGT Gauge White $190.00
Defi D-Gauge 2-1/16 inch Fuel Pressure Gauge Black $200.00
Defi D-Gauge 2-1/16 inch Fuel Pressure Gauge White $200.00
Defi D-Gauge 2-1/16 inch Oil Pressure Gauge Black $190.00
Defi D-Gauge 2-1/16 inch Oil Pressure Gauge White $190.00
Defi D-Gauge 2-1/16 inch Temp Gauge Black $145.00
Defi D-Gauge 2-1/16 inch Temp Gauge White $145.00
Defi Link (Imperial 52mm or 2-1/16in) Boost Gauge Black $206.00
Defi Link (Imperial 52mm or 2-1/16in) Boost Gauge White $206.00
Defi Link (Imperial 52mm or 2-1/16in) EGT Gauge Black $225.00
Defi Link (Imperial 52mm or 2-1/16in) EGT Gauge White $225.00
Defi Link (Imperial 52mm) Fuel Pressure Gauge Black $225.00
Defi Link (Imperial 52mm) Fuel Pressure Gauge White $225.00
Defi Link (Imperial 52mm) Oil Pressure Gauge Black $225.00
Defi Link (Imperial 52mm) Oil Pressure Gauge White $225.00
Defi Link (Imperial 52mm) Oil Temp Gauge Black $164.00
Defi Link (Imperial 52mm) Oil Temp Gauge White $164.00
Defi Link (Imperial 52mm) Water Temp Gauge Black $164.00
Defi Link (Imperial 52mm) Water Temp Gauge White $164.00
Defi Link (Imperial 60mm) Boost Gauge Black $208.00
Defi Link (Imperial 60mm) Boost Gauge White $208.00
Defi Link (Imperial 60mm) EGT Gauge Black $225.00
Defi Link (Imperial 60mm) EGT Gauge White $225.00
Defi Link (Imperial 60mm) Oil Pressure Gauge Black $225.00
Defi Link (Imperial 60mm) Oil Pressure Gauge White $225.00
Defi Link (SI Unit 52mm) Boost Gauge Black $206.00
Defi Link (SI Unit 52mm) Boost Gauge White $206.00
Defi Link (SI Unit 52mm) EGT Gauge Black $225.00
Defi Link (SI Unit 52mm) EGT Gauge White $225.00
Defi Link (SI Unit 52mm) Fuel Pressure Gauge Black $225.00
Defi Link (SI Unit 52mm) Fuel Pressure Gauge White $225.00
Defi Link (SI Unit 60mm) Boost Gauge Black $208.00
Defi Link (SI Unit 60mm) Boost Gauge White $208.00
Defi Link (SI Unit 60mm) EGT Gauge Black $225.00
Defi Link (SI Unit 60mm) EGT Gauge White $225.00
Defi Link (SI Unit 60mm) Fuel Pressure Gauge Black $225.00
Defi Link (SI Unit 60mm) Fuel Pressure Gauge White $225.00
Defi Link 115mm Tachometer Black $295.00
Defi Link 115mm Tachometer White $295.00
Defi Link 60mm Tachometer White $220.00
Defi Link 80mm Tachometer Black $220.00
Defi Link 80mm Tachometer White $220.00
Defi Link Display Unit $295.00
Defi VSD BASIS Unit $170.00
Defi VSD CONCEPT Unit $285.00
Defi Link Gauge Control Unit II $118.00
Defi Link Indicator Unit $35.00
Defi Link Single Meter Visor (60mm) $18.00
Defi Link Triple Meter Hood (Impreza GC/GG) $142.00
Defi-Link BF (60mm or 2-3/8in) Boost Gauge $236.00
Defi-Link BF (60mm or 2-3/8in) EGT Gauge $260.00
Defi-Link BF (60mm or 2-3/8in) Fuel Pressure Gauge $260.00
Defi-Link BF (60mm or 2-3/8in) Oil Pressure Gauge $260.00
Defi-Link BF (60mm or 2-3/8in) Oil Temp Gauge $198.00
Defi-Link BF (60mm or 2-3/8in) Water Temp Gauge $198.00
Defi-Link BF AMBER (60mm or 2-3/8in) Boost Gauge $236.00
Defi-Link BF AMBER (60mm or 2-3/8in) EGT Gauge $260.00
Defi-Link BF AMBER (60mm or 2-3/8in) Fuel Pressure Gauge $260.00
Defi-Link BF AMBER (60mm or 2-3/8in) Oil Pressure Gauge $260.00
Defi-Link BF AMBER (60mm or 2-3/8in) Oil Temp Gauge $198.00
Defi-Link BF AMBER (60mm or 2-3/8in) Water Temp Gauge $198.00
I have a few questions about the HUD :)
If I get the concept unit, do I need the Gauge Control Unit 2?
From what I can tell, it will just display the speed and RPM without the unit.
If I do get the gauge control unit, then how many different gauges can I display on the HUD? Do I need to buy sensors for all of the different displays? Also, what are the dimensions of the unit that sits on the dash itself?
for dimension, visit www.defi-shop.com and you've answered your own questions (they're correct answers).
you can display up to 6 (around that) different inputs, all of the sensors are going into the control unit, then from there to the HUD (or Defi Link gauges).
