1 - 3 of 3 Posts
looks good and I like the color you chose. How hard was it to do?
Thanks, it was pretty simple. The worst part was the time it took to cut the material out. Once you remove the door panel you will see a bunch of white rivet looking things. I just used a large drill bit to "bite" just enough off so I could pop it loose. Once it was off, I removed the material, traced it on the suede, cut it out, and used adhesive spray to put it on plastic piece. Mounted it back up, and used hot glue to keep it in place. The bottom portion can just be peeled off as it's just glued on from the factory.
1 - 3 of 3 Posts
