· Registered
I’ve got this srt4 been running good got my Diablo tune spot on this summer having no issues, but here recently it’s been having a random hesitation I’ll be cruising or gradually getting up to speed about 2,000 to 2,500 rpm’s and it will hesitate feeling like a misfire only for a moment my afr jumps from normal 14.7 to 16 or 17 and bounces right back in a moment. Very occasional random, My tune was set perfectly and now also if I go wot instead of being 11.5 11.7 I’m lingering staying in the 12 area on afr so I’m thinking my fuel pump is getting weak or filter or regulator clogged. I changed plugs again hadn’t been but maybe a couple months since I changed them before all was fine before. I’ve checked some wiring all looking pretty good but I did notice these plugs are all laying over in the fender well I have cai and everything has been running great until now so I don’t think these plugs are my problem, but I do have the battery temperature code and another code for one of these plugs not sure how important they are as everything was running great before and they’ve been unplugged since I got the car I bought it that way. Just curious if someone could teach me if I need these hooked up or not it appears this car has a 2003 ecu since the car is 2005 and I’m getting the battery temperature code thanks.
Automotive tire Gas Motor vehicle Automotive wheel system Auto part
Automotive tire Hood Tread Motor vehicle Automotive fuel system
Tire Wheel Automotive tire Tread Motor vehicle
Tire Automotive tire Motor vehicle Wheel Tread
· Registered
Like you speculated, I would investigate fuel issues first. Ignition issues normally cause rich conditions. A lean condition indicates not enough fuel.
The p1190 code resistor out of range is something I also have there is no sensor in this plug tan plug in pictures how important is that , it was running fine before without it.🤷‍♂️
· Registered
I’ve got this srt4 been running good got my Diablo tune spot on this summer having no issues, but here recently it’s been having a random hesitation I’ll be cruising or gradually getting up to speed about 2,000 to 2,500 rpm’s and it will hesitate feeling like a misfire only for a moment my afr jumps from normal 14.7 to 16 or 17 and bounces right back in a moment. Very occasional random, My tune was set perfectly and now also if I go wot instead of being 11.5 11.7 I’m lingering staying in the 12 area on afr so I’m thinking my fuel pump is getting weak or filter or regulator clogged. I changed plugs again hadn’t been but maybe a couple months since I changed them before all was fine before. I’ve checked some wiring all looking pretty good but I did notice these plugs are all laying over in the fender well I have cai and everything has been running great until now so I don’t think these plugs are my problem, but I do have the battery temperature code and another code for one of these plugs not sure how important they are as everything was running great before and they’ve been unplugged since I got the car I bought it that way. Just curious if someone could teach me if I need these hooked up or not it appears this car has a 2003 ecu since the car is 2005 and I’m getting the battery temperature code thanks. View attachment 150318
Could be a TPS problem?
I had the same problem regarding the battery light, having an 05 😕. I just found the battery temp sensor and put a resistor in it, problem fixed. Hope that helps!
