has any had this issue yet? it seems to be from the left side upper seat bolster. It creaks when i go into corners and over speed bumps.
If so, does any one a have a fix??
Thanks,
Mike
2004 srt 4 55,000 miles
ah right up my alley. i use to work for Lear making the seats for the Durango. Creaking noice usually means springs. try spraying some w-40 on them from under the seats. you might have to remove the seat. squeaking noise means foam and you can fix that by putting plastic(like saran wrap or srink wrap) between the cushion and the frame. if the creaking noise is still there after the w-40 get it replaced if still under warranty.
hope this helps.. let me know
