1 - 2 of 2 Posts
I am Having Very big problems with my car...My Odometer stoped working and my Temp gauge also stoped working as well..The Car runs like complete Crap the throttle sticks half open all the and i am only getting 6 PSI of boost at the most. i have a stage one computer but the dealer said that cant reflash it because my car is An 2001 with an 03 motor swap done to it and they said in 03 they changed the ignition in them with the keys with the chips in them or some dumb stuff... And need To know the best Way to Fix The Problem any help would be nice... THanks:crying:
That sounds like a wiring/computer issue.
The easiest way to check this is by finding a stock computer to swap in there. You COULD fry it though if it was your wiring that caused this the first time.
Check ALL the wiring for loose connections, shorts, abraded insulation, etc...
Could be as simple as the connectors/pins came loose from the computer or from a sensor.
1 - 2 of 2 Posts
