can someone look through there shop manual and tell me what the compression should be on an srt-4 and what the amount is that one cylinder can be off (percentage wise) from the others and still be considered within the range of being good.
thanks,
Badger....
thanks,
Badger....
I can recall the manual has ridiculous low numbers, but what I have seen so far on the forum is approx 150 psi with less than 10 psi variation from cyl to cyl. If you are in this ballpark you are good to go.
P.S: the manual says not less than 100 psi with less than 25% variation.....
