Hi guys, First of all i recently replaced my clutch (act xtss kit). I replaced flywheel, clutch pressure plate, TOB, put new billet fork, used arc bolts, torqued everything to specs.
I also replaced clutch slave cylinder and bleed the whole air out. Only thing that i didnt replace was clutch master cylinder.
Before I had and issue (except clutch splipping at 3rd and above gear on wot)
that my clutch pedal wasn't returning smoothly when slowly releasing pedal. It was intermediate with some freezes (only occurred when slowly releasing pedal).
It wasn't spongy at all but not smooth neither, more like sticky at some points.
After the install of new components everything was totally fine-100%. But then next day I realized that I should adjust my pedal (was at highest position). And then it started.... As soon as I adjust it, the transmission started making rattling noise (it was there before clutch install but after i replaced everything it disappeared).
It goes away when i press the pedal in.
I got very small leak from masxter cylinder near pedal - very small.
In my opinion its master cylinder leaking and then because of it it's not putting enough pressure on fork and TOB and its probably also letting some air get into system via seal.
What you think about it?
My clutch pedal after bleeding was not sticking but now it is doing this again.
Like I said that loud rattle started after i adjusted pedal(it goes away when i fully press the pedal in).
Any ideas?
Any ideas?
