OK. The clutch pedal has a sloppy feel to it but still is maintaining about 1/2 of the usual pressure. For the most part I can not engage it into any gear. If I let the car sit for a few hours it seems I can slip it into one gear but the motor stalls almost immediately since the clutch is at least partially engaged. The reservoir is topped off, and there is no obviously fluid leakeage.
I'm suspecting the master cylinder, but I wanted to get others opinions before I start blowing money on parts. I'd suspect to see some fluid leaking if the slave were going out.
Opinions?
~Nem
could be a ton of things. master cylinder, slave, clutch fork, throw out... you really iether have to start replacing stuff or ripping off the tranny to visually see if anything is worn or broken.
I had similare problems with my girlfriends eagle talon. her master cylinder went and in turn it shot the clutch fork and pressure plate all to hell.
