1 - 3 of 3 Posts
last nite i installed a manual boost controller and i havent gone over 16psi. now while i was driving today my CEL cam on. i checked all the hoses, and everything is on tight. does anyone have an idea of why im getting a CEL? btw, my car has 4500miles on it and i changed oil at 3000miles
Discussion Starter · #2 ·
now i put everything back to stock, and i still have a CEL........AND im only holding NINE psi. whats going on?
You need to tell us what the code is, then we can look it up and tell you what is going on. I'd guess partial throttle overboost! Turn the key to the on position, then back to off 3 times I believe. On the third try, just leave it in the ignition. Look at your odomoter and then search for the code. When I was running Stock PCM and a boost controller I got the partial throttle overboost code a lot. Hope that helps!
1 - 3 of 3 Posts
