what catch can is the easiest to install?
Weapon R is pretty easy. but i had mine in for about a day and a half and was checking under the hood and noticed oil under the cc. i take it out and it was a small crack along the length of the weld...i was pissed. sent it back and got the STS w/ bushings. much better mod.
It catches oil coming from your PCV valve before it gets into your throttle body, cold side intercooler hose, and intercooler. Some people will say that you do not "need" it and that the Dodge engineers say you don't "need" it. It's true, you don't "need" it, but if you don't have one, it will eventually leak oil on the ground and fill your intake piping and intercooler with oil like this: http://www.srtforums.com/forums/showthread.php?t=235964
This is from the how-to section:
http://www.srtforums.com/forums/showthread.php?t=97923
You don't need to spend more than $20 for this mod (which is why it's sometimes referred to the $20 catch can). You simply buy a compressed air separator, which is designed to catch water and oil before entering air tools and hold 150 psi. Don't listen to anyone who says the $80-$100 ones are better. The only thing they do better is look a little nicer. Here's my install w/ pics. http://www.srtforums.com/forums/showthread.php?t=214586
20 dollar one is really easy and works well....its like a 20 min install with everything.....yea some may do it quicker and some slower but i would say with that amount of time it should even sound easy...lol
Is the $20 easy to install with the stock air housing? What is the best 'purdy' catch can to use with stock engine?
I see a "Catch can" tread in here every few days, so figured I would get as much info in this thread as possible so when ppl searched they wouldn't need to post another catch can thread.
