This has been going on for 3 days and I've troubleshot a ton of stuff and I have not come up with a problem. I did search but no one was really having the identical problem I am.
Basically if I'm driving the car, or cruising along, it's fine - shifting through the gears at a speed (accelerating) it's fine...it's when I come to a stop, or a very slow rolling stop, where the car will just shut off (all lights stay on, though). It will not turn on instantly, either. I have to sit there maybe 1 full minute before I turn the key, then the car fires right back up. If I try to start it too soon after it stalls out, it will just keep turning over but never fire up. This only happens at a stop, when I'm waiting on a red light, or taking a slow turn or when rolling very slowly with the clutch pedal in at a very low speed. If I'm on the freeway there are no problems, nor are there any when I get on it even to redline. A/F still looks good and zero KR.
Fuel pump primes and there's appropriate fuel pressure at the rail (gauge is spot on). I have checked every fuse in the car and all are fine. I replaced coil, spark-plugs and wires, battery is spot on with voltage, alternator is working fine, etc. I see no shorts or anything and there's no unusual noises. I have not done anything to the car recently, and it's throwing no codes.
Any ideas would be greatly appreciated.
