boost leak!!!!!!!!!
re do your vac lines
what are you smokin because i want some of that good shit:bandit:foxracing12002 said:PTB!!!! learn how to drive with ptb, meaning, do not boost after 3k rpms. then you should be fine :thumbsup:
in what 4th and 5th gear.....a stock turbo car with an agp will smoke the tires if pegged between 1st and 3rd gear below 3k rpmsfoxracing12002 said:usually when you boost before 3k rpms you get compressor surge and the needle flutters. so as for what i am smokin, only the best :2thumbsup
onthedwnlow said:in what 4th and 5th gear.....a stock turbo car with an agp will smoke the tires if pegged between 1st and 3rd gear below 3k rpmsfoxracing12002 said:usually when you boost before 3k rpms you get compressor surge and the needle flutters. so as for what i am smokin, only the best :2thumbsup
