1 - 19 of 19 Posts
well i bought the car with stage one already on it. i was running 14.40 to 14.55 with no problem. now i installed atp hardpipe, perrin block off plate and a greddy rs blow off valve and the best run since install is 14.89. am also getting 3psi more now too so can anbody tell me why this is. i have done the boost leak test and that was fine.
3psi more? Which would be what total? Timing could be getting pulled..
Sometimes more power=less traction=lower ET's. What were your 60' times before/after install. Also, what were your trap speeds? A trap speed usually will show a power increase.
Sounds to me like you wasted a bunch of money on mods that do nothing for performance.
The tell tale sign of your 1/4 mile times and performance mods should be your MPH. Are you going faster? If so, traction issues. If not, problems with car and/or mods.
And people say I need the driver mod. Jeez.......no offense:hi: .
I would agree with everything that has already been said. Either traction or boost leak. Buddy of mine had a boost leak after installing a BOV and I've had first hand experience with pulled timing. Went [email protected] then after a computer reset, ran [email protected]
Sounds like you have a bigger problem than the mods you put on.
Teh driver mod is teh hardest to find. :readclose
[QUOTE='05NeonMaaaaan]And people say I need the driver mod. Jeez.......no offense:hi: .
[/QUOTE]
You still do.
You still do.[/QUOTE]
No, I need the traction mod
TheGreyGhost said:
Which is why hw spent his own money and didnt ask you for yours.......
Hey, Ghost, go ahead and give the step by step instructions on how to do a boost leak test for him!:thumbsup:
No, I need the traction mod[/QUOTE]
Well lucky for you theres a company coming out with a traction control for the SRT4 :tongue:
You still do.
Well lucky for you theres a company coming out with a traction control for the SRT4 :tongue:[/QUOTE]
I would NEVER put trac on my car. I just need some bigger wheels and some sticky tires.:thumbsup:
Discussion Starter · #14 ·
before i was sitting at 12 and peaking at 14 and now 15 and peaks at 17
Discussion Starter · #15 · (Edited)
i was getting between 2.1 and 2.3 60' and still getting the same. 96 to 97 before in the traps and now 94 to 96. but we have had hi humidity has been trouble here in kc. and kcir is a ice rink the first 330'
Santorican said:
srt4srsexy said:
do boost leak test.
Yeah and don't pressurize the car to 20 psi before turning it on, its not good :jester:
then strap a 50 trim on a motor with a knocking rod and a stock fuel system and say " Well, i am just gonna put it on and run it at a low psi cause i got a hell of a deal on it!" :stab:
1 - 19 of 19 Posts
