get a real boost leak test done
Thanx man for the input. I really have to get a real booost leak test then, but honestly I don't know how to do one :stab: Sad but true!!!!!:crying: I recently started to put my hands on my car and I guess this is part of doing that. Seeing the affects that a modification can do. Any help on this topic guys would be great :readclose ....:clap:NeonDan said:get a real boost leak test done
That's what I was thinking but I haven't gotten a chance to check them out. I'll be doing that tomorrow and will update then. Thanx for the help!Sp3kter said:if u had a bad boost leak your plugs might be fouled so check those. I hve the hks and I have not encountered that problem.
Around 3500 RPM, once it goes over it starts to bogg.Chino7385 said:how low of rpms are you going wot at?
Thanx, I'll do that also!:rofl:SRT_Maniac said:try the search button for "boost leak test" and its real simple to make your own. mine cost 13.50 to make and works well.
On one occasion the check engine light came on. I was at a low RPM in 3rd and I WOT into 4th and the car wanted to shut off. I lead off the pedal and a few seconds later the check ingine light came on. That was the only time it appeared.Jagok1 said:No check engine light right? Sounds TPS related to me.
I'm guessing that what it is cause I checked my plugs and they are good. Would u happen to know where I can fix this? Thanxaalvasrt4 said:TPS!! had the same problem
The TPS is the sensor hooked up to the TB(on the bottom, the top one is the IAC sensor) have your car on and just wiggle the wire. If the car jumps, then its the TPS:readcloseflmredsrt4 said:I'm guessing that what it is cause I checked my plugs and they are good. Would u happen to know where I can fix this? Thanxaalvasrt4 said:TPS!! had the same problem
