well either you have your map wire hook up wrong since thats where your pulling fuel from
OR you got a bad unit
I'll double check and triple check the wiring.tinctorus said:well either you have your map wire hook up wrong since thats where your pulling fuel from
I hope so. I just got the car a year this month. It didn't do this last summer. I kept hearing about this summer gas issue. I guess I will wait til the fall to see if it changes. I will tune to 11.5 AFR. I was thinking return line in the future.tinctorus said:its just summer gas mine is doin the exact same thing man its taking longer to crank over
also try not taking so much fuel out you should have it aroune 11.5-11.8 at redline
I would switch to a walbro. When I had the ptp fpr mod, it worked great for about 5 months then my pump started whining to before it went out. So if you could get the walbro and do not put the fpr mod in that one. I did that and I had too much fuel.dhinez said:i doubled checked the wires and i had the map wire hooked up to the tps wire. i rewired and everything works great. I'm pulling 16% @ Hi Throttle and my AFR is 12.x to redline.
I do have one question. My car is getting really hard to start. It went from starting in 2-3 seconds to starting with 2-3 cranks. I took the fpr out and cleaned it. No dirty gas came out. I also took the sensor on the side of the throttle body(not the tps) and cleaned it. My fuel pump makes a really loud whining sound. I thinking of changing my fuel pump to a walbro. Is there anything i can do to help my starting?
