1 - 1 of 1 Posts
Ok guys here's what happened. I fixed the boost leak I was having, then did some tuning when I noticed on my gauge I'm only boosting 5psi. When I drive normal I can pull 10psi, then it drops to about 3-6psi. My wastegate is set for 14 psi. I'm going to try the BOP. Right now all I have is the Turbo XS adapter kit's check valve installed on the pink line. Yes it's going the right way because I had this problem before. Any advise welcome.
1 - 1 of 1 Posts
