So... How hard is it to rebuild the front calipers. I stopped by the local auto parts and the rebuild kit only had the main rubber gasket.. a second rubber gasket and a hard rubber plug. What kit should i be looking for...
thanks for info..
its actually pretty easy. use some compressed air to blow on the inlet fitting. this will pop out the piston. remove the piston and the o-rings. replace the o-rings and pop in the piston. good to go
what rebuild kit should i be using on these... want to make sure the kit im looking at is right
If you're concerned about the brand, just order Mopar. When replacing the piston, wet the sides of the cylinder with clean brake fluid to help the o-ring slide down into it easier.
