1 - 17 of 17 Posts
What is your name?: Adam Youngblood
What is your Email Address? ayoungblood84 --at-- gmail d0t c0m
What is your City? : Royal Oak
What is your State? : MI
What is your Zip code? : 48067
Cell phone to text : (586)Five49-three4three9
PICTURES:
Shipping included unless noted
OEM PARTS:
USED OEM 03-05 SRT-4 Neon Flex Plate // Flywheel -- $30 Some rounding on clutch bolts
USED OEM 03-05 SRT-4 Neon Transmission Inspection Cover Starter Shield Plate -- $30
USED OEM 03-05 SRT-4 Neon Cold side pipe - $35
USED OEM 03-05 SRT-4 Neon Airbox $50 - shipping not included
USED OEM 03-05 SRT-4 Neon Transmission Mount $30
USED OEM 03-05 SRT-4 Neon Lower Mount $30
USED OEM 03-05 SRT-4 Neon Upper Mount $30
USED OEM 03-05 SRT-4 Neon Starter - $35
USED OEM 03-05 SRT-4 Neon Intake Manifold - $75 - Painted Red, shipping not included SOLD
USED OEM 03-05 SRT-4 Neon Oil Dipstick - $25
USED OEM 03-05 SRT-4 Neon Power Steering Pump - $60
USED OEM 03-05 SRT-4 Neon Oil Cooler Hard line - $20
USED OEM 03-05 SRT-4 Neon A/C Compressor - $65
USED OEM 03-05 SRT-4 Neon Cam Gears - $20
USED OEM 03-05 SRT-4 Neon Exhaust Mount Brace - $20
USED OEM 03-05 SRT-4 Neon Fuel Pressure Regulator - $20
USED OEM 03-05 SRT-4 Neon Crankcase Breather line - $20
USED OEM 03-05 SRT-4 Neon Ignition Coil - $30
USED OEM 03-05 SRT-4 Neon Oil Cooler - $30
USED OEM 03-05 SRT-4 Neon Oil Cooler - $20 - Missing pieces
USED OEM 03-05 SRT-4 Neon Intermediate Axle Shaft Bracket - $20
USED OEM 03-05 SRT-4 Neon Transmission to Engine Mount Bracket - $25
USED OEM 03-05 SRT-4 Neon Intake to Throttle Body Spacer - $20
USED OEM 03-05 SRT-4 Neon Fog lights - $20
USED OEM 03-05 SRT-4 Neon Alternator - $45
USED OEM 03-05 SRT-4 Neon Oil Pickup - $20
USED OEM 03-05 SRT-4 Neon Throttle Cable Bracket - $20
USED OEM 03-05 SRT-4 Neon Upper Thermostat Housing / Neck - $20
USED OEM 03-05 SRT-4 Neon AIR CONDITIONING AC BRACKET W/ TENSIONER - $40 - shipping not included
USED OEM 03-05 SRT-4 Neon TIMING COVER LOWER - $15
USED OEM 03-05 SRT-4 Neon ALTERNATOR BRACKET WITH TENSION BOLT - $30
USED OEM 03-05 SRT-4 Neon POWER STEERING BRACKET - $20
USED OEM 03-05 SRT-4 Neon HARMONIC BALANCER / PULLEY - $25 - Heavy to ship, shipping not included
USED OEM 03-05 SRT-4 Neon MAIN COOLANT LINE FROM WATER PUMP - $30
USED OEM 03-05 SRT-4 Neon TIMING CRANKSHAFT SPROCKET - $20 - 939AA
USED OEM 03-05 SRT-4 Neon TIMING BELT TENSIONER - $25
USED OEM 03-05 SRT-4 Neon UPPER ENGINE MOUNT BRACKET - $30 - shipping not included
USED OEM 03-05 SRT-4 Neon INTERCOOLER - $60 - Bulky to ship, shipping not included
USED OEM 03-05 SRT-4 Neon HOT SIDE HARD PIPE(large) - $50 - Bulky to ship, shipping not included
USED OEM 03-05 SRT-4 Neon HOT SIDE PIPE (small one) - $20
Modified OEM Parts
USED 03-05 SRT-4 Neon CATLESS DOWNPIPE with O2 Bung - $50 - Bulky to ship, shipping not included
USED 03-05 SRT-4 Neon Aluminum Cold-side Hard pipe for SSQV BOV, IAT and threaded Meth nozzle - $40
USED 03-05 SRT-4 Neon DCR 5-layer head gasket - $40
Other Parts
USED 03-05 SRT-4 Neon Spark Plug Wires - $15
USED 03-05 SRT-4Neon MSD Ignition Wires - $20
NEW SRT-4 FRONT BRAKE ROTOR 126035 - 2 AVAILABLE $20/each, shipping not included
USED DASMOPAR MAP CLAMP (Voltage Clamp) for SRT4 - $20
NEW SCE ICS TITAN HEAD GASKET S92684 - $120
NEW Aluminum Hot side pipe - $25
USED RC 750cc Injectors - $150 - Sold as-is, been on shelf for 4 years. Working when pulled - Missing some o-rings
USED JE Pistons Stamped 87M and 520106 - Stock bore SRT-4(I'm pretty sure) - Good condition - $250
USED 4" to 3" 90* rubber intake adapter w/T-bolt clamps - $15
USED Braided oil line for Garrett DBB Turbos (Oil and water) - $5
Discussion Starter #10
Just the pistons. Rings are cheap.
I'll grab a picture Mike (even though it was a month ago).
If anyone is seriously interested in any parts, please TEXT me at the number above.
Still have Airbox? I only need the lid on the airbox but I'll guess I will take the whole thing if you still have it.
1 - 17 of 17 Posts
