i know this is an old thread but how did you get it out?! im in the same position and the bracket in front of the brake booster wont move so i cant pull it out. how did you do it??
I'm assuming you have the pedal disconnected and the 4 bolts off, you need to take the lines off the master cylinder and it will just come right out as an assembly.
You'll need someone with a scan tool to bleed the abs module though.
yeah i disconnected the pedal and all the bolts. i took out the master cylinder. your saying i have to take the abs module out too. it seems like the abs module bracket is whats in the way and i cant get it to move. i took out the three bolts attached to the module but i dont want to disconnect all the line to the module if i dont have too
It takes alittle persuasion to get the booster out... from what i recall you dont have to remove the abs unit down on the rail.... should be plenty of room to get it out but cant remember off hand...
