I bounced off the tach the other night street racing and i was just wondering if it did any damage or if the back fire is the ignition system pulling fuel and timing? I interested to know if it did any damage.
Car should be fine...you need to drive your car a bit at varying speeds to learn when you can and cant downshift...or where it will put you if you do.
I like to downshift to 3rd between 40 and 50 mph because that usually leaves you in a good RPM range, around 3k, if you shift down at 70 your talking 5k and if your on it you'll be at the rev limiter quickly...
Downshift
If you do downshift and miss a gear(go intoi a lower gear) you can over rev it, i have doen it in my buddy's car, hit 2nd at like 70 and went to like 7000 rpm.
