I purchased the AGP bop. What is the best way to seal the bop? RTV selant or can I use the mopar bov gasket? What about bolts? It didn't come with the bolts. Do I use the bolts that came with the mopar bov?
you can use the mopar gasket.....not the bolts tho...Use the factory bolts (shorter). If you use a sealant (RTV) use hi temp copper. It comes in a shinny copper tube. Also use lock washers on the factory bolts. I you dont have the factory bolts try the mopar long bolts but try the factory first. Hope this helped :hi:hydrohopper said:I purchased the AGP bop. What is the best way to seal the bop? RTV selant or can I use the mopar bov gasket? What about bolts? It didn't come with the bolts. Do I use the bolts that came with the mopar bov?
