boost
555 Views 1 Reply 2 Participants Last post by  scrivenerc
when i really hammer it i can only get about 11 or 12 pounds of boost. its a 2004 stage 1 pcm, mopar BOV, magnecor wires, and a cold air intake. if i put an agp wastegate and a turbo xs standard boost controller will i get a lot more power? should i be getting more boost as my car is in its current state? im not sure what the stock boost is.
thanx
1 - 2 of 2 Posts
sounds about normal, have you checked for boost leaks? AGP wga and taking boost away from the pcm and you will get more power. Just dont take it above a 17psi spike and 15 redline though, unless you have a way to moniter you a/f ratios.
1 - 2 of 2 Posts
