1 - 7 of 7 Posts
There a pic of one in the maintenance section on srtoys.com. I make them the same but use a 90 deg. elbow to make it easier to fill with air..
AnotherNeon said:
Anyone have directions on how to make a boost leak tester. I did a search and it only came up with one i know there are others out there
Look at my photobucket account ... look under boost leak testers. thers is 3 parts to making then.
1. A Valve stem. Buy 2 at walmart for 1.75 a set
2. A 2inch - 2inch Rubber piece roughly 4 inches long. Buy at home Depot in the plumbing section
3. A PVP End cap, preferable smooth, that fits inside it. (home depot again)
then you put the end cap inside the rubber peice, tighten that bitch down as tight as you can, drill a hole inside it roughly 1.2 inch thick, and pull the valve stem through,
no glue or anything needed, they will seal themselves if you do the clamps tight enough. roughly 6 or 7 dollars and there u go :)
1 - 7 of 7 Posts
