ive only been able to boost about 5-6 psi. while driving. after checking for boost leaks i noticed at about 5 psi. my wga start to open up, is this the problem and how can i fix it? the wga is brand new the dealer just installed it last weak. thanks for any help.
if it is the stock wga then ist fine that is all it can do. the stock solinoed is what controls the boost over that. what mods do u have and have u reset the pcm(disconnect battery terminal)?
isnt the stock wga set to open at 11- 13 psi. i have no mods that effect boost. and yes i did reset the pcm. sounds like im sol. until stage 1.
the computer is what makes it boost more like and ebc but the spring in the stock wga is only good for 4-5 lbs. i would sugest getting a ptp wga will help u out and u can boost about 17 psi no problem on s0. good luck just tight all clamps and block of the stock boost leak that goes in to ur intake
4 lbs stock wga - forge makes adjustable wga - agp is 14 lb
