thanks alot, that one helps alot more since it has one specifically for one of the BOV's i have on it
I had a red tube (inlet pressure?) where the rubber connector was torn.im not sure if i have boost leak but car sputers when boost is around 10-15psi . looked under hood and found a small red hose thing not plugged into anything.. no clue where it should be plugged into.
Perfectly normal, Junior.so ive read through this thread. my car runs about 14 psi until about 5500 than drops off to about 12 at redline. is that a boost leak or is it similar to horse power peaking a little before redline
Hey guys I have an issue.... I have a boost leak tester that I bought from modern. I plugged the one air intake hose with an extension then left the valve cover breather opened. When I try and pressurize the system nothing happens (boost gauge does not even move) I don't know if I'm missing a simple step but if someone could help I'd appreciate it. I'm using a compressor for the test and I can hear the air going in. When my car is running I spike around 14 then fall to 10lbs at redline. Any help is appreciated. Thanks guys!!
