I figured with all these guys dropping boost and not knowing where to begin, this thread will help those where to start looking. I know to plenty of you this is your first turbo car.
In this Discussion thread we will reveal the real leaks vs. hoses popping off etc..
If someone can get the method of pressurizing the system and you have pics, we need the how to. I can paste it on this first post for all to see.
This is a must (Pressure Testing) before you go out and think something is wrong with your car. Sometimes it gets as simple as a stripped worm drive clamp.
~ Lost a reading on your Boost Gauge? ~
the boost gauge is tapped into the brake booster line, it can be found on the hard plastic fitting to the brake booster. The line is very thin. a small wire tie will keep it from coming off. I will get a picture up sometime.
http://www.srtforums.com/forums/attachment.php?attachmentid=9532
