1 - 2 of 2 Posts
These 4. Not listed on AGP's how-to. Do not want to over torque them. Cannot find the torque specs anywhere. Surprised they did not come with lock washers.
The ATP-based cast manifold kits should be around 61 N·m (45 ft-lbs). You could also drop AGP an email or give a call and see if they require something different.
Only other thing to add, you may want to use a high-temp nickel (silver color) anti-seize on the threads. Some of the fastener torque values can be different if you install dry or with a coating.
1 - 2 of 2 Posts
