1 - 20 of 21 Posts
whats the best type of gasket to use under the block off plate.
have seen some that use copper flashing and some that use high temp sealer
if you use sealer do you want to just put it around the outside edge of the plate or do you wanna put a thin coat on the whole plate?
silicone, just spread it around the outside edge only though. worked awsome for me.
i put high temp silicone around the edge and a small strip on the dividing part in the middle. is that okay?
i just figured if you put a thin coat on the whole plate then there wouldnt be any worries about leaks and just let the thing sit over night and it would dry to the block off plate anyways. correct me if im wrong with that idea
high temp copper sealant?
^i used the gray silicon because it is high temp and oil resistant. i smeared it on the whole plate and no leaks yet. i even ran the car about an hour or two after install and it was fine.
edit: this is directed to stryker
The best thing to do is:
Buy a paper gasket sheet from an auto parts store (autozone for example) and a can of copper spray gasket stuff.
Trace the gasket using the BOP and also mark the holes. use a hole punch to make the holes (its the cleanest way IMO).
Once your gasket is cut out spray both sides with the copper gasket stuff (atleast 2-3 coats on each side since it will soak some of it up).
Let it dry for a minute.
Wipe off the turbo where the gasket will go so that its clean and no oil.
Install the gasket and the BOP.
I've tried the gooey gasket maker and its ok, not the best but it can work.
Copper-metal gaskets are good as long as both surfaces are PERFECTLY flat.
Plain paper gaskets dont seal very well.
X2...
I try to use as little sealent as possible in conjection with a paper gasket...If you ever step up to a big turbo and want to sell your stock turbo to someone who doesn't want a BOP, it's going to be a hell of a time scraping off the sealant...
the copper spray (luckily) rolls off the aluminum with your fingers. Its far superior then the paste stuff that takes a razor to get it all off.
Discussion Starter #11
this copper gasket maker you are talking about is it similar to this, this was all the local napa store had, is this the correct stuff?
napa permatex copper spray-a-gasket hi-temp adhesive sealant
fast drying metallic copper sealant helps dissipate heat, prevent gasket burnout and improve heat transfer. fills minor surface irregularities. seals instantly. fills hot spots and surface imperfections. temperature range -50- 500f resists all types of automotive fluids esp gasoline
suggested apps
cylinder head gaskets, carburetor gasket exhuast manifold gaskets and other high temperatire apps
so just make a paper gasket sized to fit the block off plate and spray it with the sealant? do you let the sealant dry first or put it on when it still wet just wanna get the job done right the first time thanks for all your help
I used high-temp paper gasket maker from Autozone. Traced out pattern with the bop and used a hobby knife to cut out the holes. Done and done.
suggested apps
Yep, that stuff will work. After you spray it on the paper gasket just give it a minute or so to get gummy; when it first comes out its seems like a little thicker then chocolate milk, so it can run if there is enough in one place.
Do this and when its gummy you can easily play with it without dripping gasket maker or getting it all over the place.
Just a plain paper gasket is fine, dont get me wrong, but any condensation build up from the intake, or from the outside of the turbo will weaken the gasket and shorten its life. I doubt anyone would have an issue with this but it is a possibility. The copper spray should easily prevent this.
I hear you.
I forgot to use a gasket or anykind of silicon but guess i got lucky as i have no leaks around the block-off plate...i wish i would have used the copper gasket maker that i have now
Hmmm have you done a leak test? That sounds risky.
Discussion Starter #18
now that we got that out of the way is there any one block off plate that is more popular then another or one that works better?
Yep, it was one of my first mods, about 35k miles ago and i did a boost leak test last month and no leaks, i was quite surprised to say the least, especially when my only leak was the little rubber gormet that holds the ait sensor in the UPP.
any really. i've only used agp though, but they work great.
1 - 20 of 21 Posts
