1 - 2 of 2 Posts
If I get a Big Turbo Kit will I pass emissions in PA. I know she will run better and cleaner. But that doesnt help on are Emissions. They scan threw the OBDII port and look for the codes as you guys my already know.
So, If I Run low boost and throw the Stage O computer back in she should pass? you can turn the Emanage off correct?
So, If I Run low boost and throw the Stage O computer back in should pass? you can turn the Emanage off correct?
You should pass no problem as long as all your sensors are working. You will have problems if you remove the cat or one of the oxygen sensors. Stage 1 PCM should take care of the codes. Make sure you do not have any codes in the computer when you go for the inspection.
Percy
1 - 2 of 2 Posts
