Its the stock worm clamp right? Loosen off the worm clamp, then loosen the two bolts that hold the charge pipe on (under the car). Install a t-bolt clamp and tighten.
If you slide the charge pipe slightly down you can get the new clamp onto the back of the turbo easier then actually opening the clamp and trying to close it around the pipe.
I hope this didn't confuse you more.
Good Luck
John
Good Luck
John
