· Registered
I've been thinking of redoing the grounding on my SRT and I need to know what the best places to ground this engine are. I know P-werks sells a kit but I can't and won't spend $80 for 7 wires :stab: and even the eBay one is hard to get in a color I want, so this leaves my to do a custom kit. Also, what would be the best gauge of wire to use?
· Registered
Go to Pepboys and get a battery ground strap about 18" long and go from the battery ground to the 8mm hole under the intake manifold outter most bolt on the driver's side. The other side of the head is ground to the chassis from the factory.
· Registered
Is it a 8mm or 10mm bolt, because I was looking and I only saw a 10mm bolt. Just double checking,
· Registered
Bolt size to get from hardware store
it's a 8mm 1.25 pitch 20mm long bolt.
