1 - 3 of 3 Posts
i have the agp adjustable wga i love the way it holds boost, it hits the desire psi and just stays there glued all the way to red line, here is my question; do you realy need a boost controller? i hear spike is added torque, but then again if you go over 17 pounds the computer pulls timing so that would mean spike is not goodover 17psi rigth? i have my agp wga set at that already,so why the need for a BC?, what if you have a map/tip clamp? im waiting for mine form PTPerformance, if you have it set so it tricks the pcm to achieve the desire A/F ratio, and then you hit spike wouldnt that lean you out even more? sounds to risky to me.
the only reason i want a BC is so i limit the boost on first gear, thast what i like about dual stage BC, but still having the map/tip clamp the spike worries me.
I apreciate any inputs on this subject, and thank you in advanced.
1 - 3 of 3 Posts
