I see the engine is using balance shafts similar to the 2.5 in my Daytona... And since they are actually pretty similar, I would imagine the first mod that should be done would be to remove the balance shafts, yes?
Its really not that hard to do. In my 2.5 I took them out with the engine out, but I could have easily done it just by taking the oil pan off with the car in the air, and in fact thats how most people do this mod.iwntasrt-4 said:This seems like it will be a nasty project, dropping the motor down to get to them. Maybe I can get some guys at my brothers shop to do it for me, ill just bring in a case of beer and see what they say...
No I would say it wont increase your turbo lag...in fact it probably wont affect it, but you will have more power all across your powerband (even before the turbo spools).Exhaust Depot said:For those who are new to the turbo seen, when you add a lighten flywheel , the engine spins easier being that there is less mass to turn. But that also means that the vehicle has less of a load which means it needs less fuel to maintain the power. Less fuel = less exhaust for the turbo to spool on the lower end.
If you remove teh balance shafts I think your lag will go up on the turbo?
