1 - 20 of 25 Posts
Anyone have a Newer E-01 greddy boost controller? I have a few questions.
ask blue04soon... Roderick has one but it's not installed yet.
:meow:
:meow:
Ok well fyi the newer either E-01 or jsut the software, allows for a speed adjust boost setting for 3 stages, Off till X rpm, Low till X rpm, and hi till X rpm, I am finding I am the only one currently with this option but I only got mine like 4 days ago and found this out yesterday in the instal. Now the Emanage gets deliverd today and this should be fun. Hopfully will make it Sun to dyno it also.
right... the software let's you set your boost according to rpms.
Robert... go on the Nor-Cal site and find Starkie. He did a how to install with photographs... also you can ask him what his setting is.
Do a search on the Nor-Cal site for "E-01." That should bring up a list of threads.
:meow:
OOOPS to daym early needed coffee.
I MEANT SPEED...
MPH
It has a Off setting for BC at x rpm to x rpm, then a Low setting for x - x rpms and then a High for x - x rpms.
I have yet to confirm this with anyone else except one VERY cool guy / site www.mohdparts.com , The E-manage & E-01 Source, that this is a new feature. I am calling greddy in about 15 min to ask more specifics with the new(er) feature I cant find any info on.
This is from that site... which is also in the manual.
did you get the MSD ignition
Discussion Starter · #9 ·
Ok and? :lol: ya lost me. There's no mention of a Speed induced boost mapping?
:bandit:
Oh you meant SPEED????
No it doesn't work by speed... damn too early for me. I totally lost your reply... duh. I asked and they said it's RPM specific.
Try calling Greddy...
Discussion Starter · #11 ·
I did get the coil and Coild adapter. both are to be here today or tomorrow.
Total I got...
Profect E-01
Emanage
Pressure harness
Pressure adapter harness to link Emanage to E-01
Injector harness for Eman.
Adapter harness for inputs and outputs of the E-01
MSD coil
MSD coil adapter
And working on a PLX M-250 Wideband / Narrowband unit, that thing is trick for this setup. but 300$ daym this is getting costly lol
Discussion Starter · #12 ·
The new software does have speed specfic mapping, the newer stuff that is. Their still closed, will try again in a few.
Looks like your set.
So how much did you pay in total?
:meow:
Discussion Starter · #14 ·
alot lol.. seriously though, I would have liked to go through hector for this stuff but the price was a little factor when you add all this up, so that site I mentioned up there, well he is liek a emanage guru also and has a big yahoo site even, well he has the BOMB service and prices! Really good experience with him so far.
Now I need to finish a incar computer setup I have in the works. I have the completed system that is the size of a single din car stereo, but need all the other crap and then I can link the emanage to it and never need a laptop or such, just use the incar setup, which will do everything else except what my wife does for me lol
LOL! Have fun and let me know when you get it installed!
Discussion Starter · #16 ·
well greddy is lost and thier E01 specialist will be in, in about a hour so I am to call back. they said its very poss that it was done over sea's and its just not trickling over here and they are not up to date on it yet. Well see.
keep me informed! thanks robert.
cat
I haven't connected to the speed sensor at all yet but we also have that feature at the bottom of the options. really didn't play with it since the boost controller does a nice job at controlling boost, but we also have an externatl wastegate.
Discussion Starter · #19 ·
How old is your E-01 or do you knwo what versions of the software your running on it?
I think the Speed settings woudl be the best since Sliced bread.. :)
Traction in 1st ( any rpm up to like 3000) with it hitting 18 is a loss of all hopes lol then second I would really like that same 18-19psi at 2000 up to 5000 but theres no way with out that speed selector to obtain this?
Thinking, set the AGP to like 10psi. then the E01 "off" till like 20mph then "low" at 18psi till like 45 then have a high override set (like 20?) for any reason that I may want to try for more in a pinch with a mounted switch.
now this is what i have bean waiting for
mine has the speed setting also have only had my e-01 for about a month
as far as i can tell you need the external harnness and connect to the speed sensor wire i just need to stop being lazy and order that harness which i think i will do now since i am not the only one i kept asking this before but everyone kept saying i was crazy
keep us informed
1 - 20 of 25 Posts
