anyone have this problem(p0068)when using piggy back with larger throttle body?
476 Views 2 Replies 2 Participants Last post by  Dusan05
P0068-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION
When Monitored and Set Condition:
When Monitored: With the engine running and no MAP Sensor or TP Sensor DTC?s set.
Set Condition: The PCM determines a valid range in which the TP Sensor should be, at
a given RPM/Load. The actual TP Sensor voltage is then compared to this value. If the TP
Sensor voltage does not fall within the expected range within a predetermined time an
error will be detected. Two Trip Fault.
POSSIBLE CAUSES
GOOD
i had this problem when running 62mm throttle body and safc 2
1 - 3 of 3 Posts
POSSIBLE CAUSES
GOOD
if anyone has had same problem or fixed it. i had to remove the safc2 i need to use a tuning device on my car bu tdont wanna run into the same problem if i run another piggy back and dont have money for ems or stand alone
its a matter of hooking your solenoid lines back up.. the pink one in particular.. there was a good post on it, and how to fix the problem.. trying to find it now
1 - 3 of 3 Posts
