If you want better handling, you could assume that the weight distribution is the same, and use regular neon lowering springs, although the SRT is a little heavier. I would reccomend waiting for a spring set tuned for the SRT. As for struts, you could either wait for struts to be produced for the SRT or use adjustables for an 03 Neon. They
should fit OK, and the valving should get stiff enough to improve on the stock SRT dampers.
I would reccomend waiting. The stock dampers are from Tokico, and probably pretty good, although maybe a
little soft. Let somebody else (like Koni or Progress) worry about having the FIRST lowered SRT. They can afford to
[email protected]#% their cars up, and they have the resources to really tune the handling, thus making the springs you eventually buy for the SRT better suited than Neon springs.
My .02
