1 - 2 of 2 Posts
I start one of these every year. Just checking to see who is still out there and if anyone new has joined
Discussion Starter · #2 ·
Ok here's the setup that I'll be starting with this year
1.Tire Brand - BFG gForce Rival S 1.5
2.Tires Size - 245/40/17 maybe going to 235/40/17
3.Pressure front - 45psi
4.Pressure rear - 40psi
5.Same Size tires front and rear - Yes
6.Front sway bar - Stock
7.Rear sway bar - 24mm Progress 3-way adjustable bar (on softest setting now)
8.Front brake pads - Hawk High Performance Street 5.0 Brake Pads
9.Rear brake pads - Hawk High Performance Street 5.0 Brake Pads
10.Brake Fluid - Valvoline DOT4 Synthetic Brake Fluid
11.Front Camber - negative 2.4
12.Front Toe - 1/16" out
13.Rear Camber - Negative .6
14.Rear Toe - 0"
15.Struts brand - KONIs (Nick's aka "fastneons" ProParts modified set)
16.Front Stuts - 1/2 turn off full stiff
17.Rear Struts - 1/2 turn off full stiff
1 - 2 of 2 Posts
