I start one of these every year. Just checking to see who is still out there and if anyone new has joined
Discussion Starter #2
Ok here's the setup that I'll be starting with this year
1.Tire Brand - Bridgestone Potenza RE-11A
2.Tires Size - 245/40/17
3.Pressure front - 45psi
4.Pressure rear - 40psi
5.Same Size tires front and rear - Yes
6.Front sway bar - Stock
7.Rear sway bar - 24mm Progress 3-way adjustable bar (on softest setting now)
8.Front brake pads - Hawk High Performance Street 5.0 Brake Pads
9.Rear brake pads - Hawk High Performance Street 5.0 Brake Pads
10.Brake Fluid - Valvoline DOT4 Synthetic Brake Fluid
11.Front Camber - negative 2.4
12.Front Toe - 1/16" out
13.Rear Camber - Negative .6
14.Rear Toe - 0"
15.Struts brand - KONIs (Nick's aka "fastneons" ProParts modified set)
16.Front Stuts - 1/2 turn off full stiff
17.Rear Struts - 1/2 turn off full stiff
Awesome! Id like to do the same with mine someday. You should check out facebook and look up Jake Layman. He has some great videos and has a kick ass looking car. IDK if he is on here or what his user name would be..
