1 - 10 of 10 Posts
Getting ready for some cone chasing and just wondering if anyone is still out there in 2017. Still doing G-Stock after all these years
Discussion Starter #2 (Edited)
So here's the last setup I could find for my car on the forum (from 2013, there's got to be a newer one somewhere, I just couldn't find it)
1.Tire Brand - Dunlop ZIIs
2.Tires Size - 225/45/16
3.Pressure front - 40psi (was 38psi)
4.Pressure rear - 40psi (was 36psi)
5.Same Size tires front and rear - Yes
6.Front sway bar - Stock
7.Rear sway bar - 24mm Progress 3-way adjustable bar (on softest setting now)
8.Front brake pads - HP+
9.Rear brake pads - HP+
10.Brake Fluid - Valvoline DOT4 Synthetic Brake Fluid
11.Front Camber - negative 2.4 (was only -1.5 when meassured Friday)
12.Front Toe - 1/16" out (was 1/8" in)
13.Rear Camber - Negative .6 (still thinking of going more)
14.Rear Toe - 0" (but still thinking of 1/8" to 1/4" out)
15.Struts brand - KONIs (Nick's aka "fastneons" ProParts modified set)
16.Front Stuts - 1/2 turn off full stiff (was 1/4 turn off full stiff)
17.Rear Struts - 1 turn off full stiff (was 1/4 turn off full stiff)
Next post will be what the care is now after I work on it
Here's Adam's setup from about the same time
1.Tire Brand - BFG
2.Tires Size - 225/50/16
3.Pressure front - 44psi
7.Rear sway bar - 24mm Progress 3-way adjustable bar (on softest setting)
9.Rear brake pads - stock
10.Brake Fluid - cheap stuff
11.Front Camber - not sure, pulled out just a little to prevent some tire rub, probably -2.0 ish? Tires still rub for an event or two from new
12.Front Toe - 0
13.Rear Camber - same as front, not exactly sure, as much as I can with a slight rub on the strut.
14.Rear Toe - not aligned, move it about one flat on each adjuster before each event towards toe out.
15.Struts brand - KONIs 1st gen proparts
17.Rear Struts - 1/2 turn off full stiff
fellow autocrosser here.
1.Tire Brand - Continental Extreme DW
2.Tires Size - 225/45/17
3.Pressure front - 42psi
4.Pressure rear - 32psi
6.Front sway bar - Hotchkiss
7.Rear sway bar - Hotchkiss (stiffest setting)
11.Front Camber - -2.0
12.Front Toe - 0
13.Rear Camber - -2.0
14.Rear Toe - .02
15.Struts brand - BC coilovers
16.Front Stuts - full soft
17.Rear Struts - full stiff (only when autocrossing)
don't know if I'll get anymore runs in this year because I just moved to Charleston, South Carolina and my car is still in Tampa, FL
I haven't run the car at an autocross in several months. Did an event Sunday in the Mustang because I didn't want to be dealing with the SRT-4 in the heat. Car runs in SMF when I do take it out.
does it perform poorly in the heat?
Discussion Starter #8
Ok here's the setup from todays event at Miller Park in Milwaukee. Car felt good. No "ICE MODE" problems at all. I thank the new Hawk High Performance Street 5.0 Brake Pads for this. The 245/40-17 fit well and do not rub.
1.Tire Brand - Bridgestone Potenza RE-11A
2.Tires Size - 245/40/17
3.Pressure front - 45psi
8.Front brake pads - Hawk High Performance Street 5.0 Brake Pads
9.Rear brake pads - Hawk High Performance Street 5.0 Brake Pads
14.Rear Toe - 0"
1 - 10 of 10 Posts
