ok im sorry for making another worthless agp wastegate thread but i really need help cause this is soo annoying....ok i origionally bought a forge wga and it either spiked like crazy or built boost really slow so i tried adjusting it but there was no happy medium. i know the arm on the manifold is supposed to be all the way to the drivers side in order to spool fast, but the problem is when i moved it all the way is when i would get the spikes and when i moved it halfway i would get the slow building boost and i now have a agp and its doing the exact same thing...stock lines with the red line removed, any help would be so greatly appreciated thanks alot guys
did you cap the up-pipe hole?
Did you cap off the hole that the red line went to on the up-pipe?
Just making sure because this would be a huge boost leak and would cause a big problem for you.
i've heard using the agp wga on stock lines is bad. someone said it blew there motor.
nigel
