Just pulled the alternator....Dam this job sucks!
Pulled it out the bottom through the axle hole. But heck this was worst alternator job I've had.
I heard of pulling it off the top...which didn't look feasible even with the valve cover off. Heat shields, etc....still dam!
I may test it soon since I need to replace the valve cover gasket anyways. But the firewall lip look to close to call.
The other part was removing the "mid" axle....forget what it's called again....but you loose tyranny oil! You have to remove it to clear the alternator!
Seems up top may be the route to go next time if I keep this Neon.
Note to all if your replacing the alternator from below...it would be a good time to replace all parts mentioned above while your at it.
Oh not to mention I received a alternator with a bent pulley....so make sure you compare yours against a rebuilt one and check for issues. I'm glad I caught that before installing it. Received a replacement and it looks New! Fingers crossed 🤞
