1 - 17 of 17 Posts
Automotive Recall and Technical Service Bulletin Titles for 2005 Dodge SRT-4 L4-2.4L Turbo VIN S.
http://www.alldata.com/TSB/16/051686fi.html
TSB Number & Issue Date TSB Title
D46 JAN 05 Recall - Reprogram PCM for Emissions
23-014-06 MAR 06 Wipers/Washers - Wipers Smear or Streak Winshield
19-008-05A NOV 05 Steering - Revised Power Steering Bleeding* (FIRE)
23-035-05 JUL 05 Body - Circular/Ring Marks on Glass
23-022-05 APR 05 Interior - Low Gloss Interior Trim Care
11-001-05 JAN 05 Exhaust System - Unequal Exhaust Tip Alignment
23-049-04A DEC 04 Body - Sunroof Vents Only/Won't Open or Close
19-010-04 NOV 04 Power Steering - Additive Prohibition
08-020-04 MAY 04 Vehicle Theft Alarm (VTA) - Activation Information
Automotive Recall and Technical Service Bulletin Titles for 2004 Dodge SRT-4 L4-2.4L Turbo VIN S.
http://www.alldata.com/TSB/16/041686fi.html
24-003-03 MAY 03 A/C - System Sealer Usage Prohibition
18-012-04 MAR 03 Ignition System - WOT Acceleration Stumble
Automotive Recall and Technical Service Bulletin Titles for 2003 Dodge SRT-4 L4-2.4L Turbo VIN S.
http://www.alldata.com/TSB/16/031686fi.html
C24 SEP 03 Campaign - Owner's Manual Oil Recommendation Update
18-018-03 APR 03 Engine Controls - Erroneous MIL/DTC's
Thanks hemidakota... :thumbsup:
NHTSA
Office of Defects Investigation
Make : DODGE Model : SRT-4 Year : 2005
Manufacturer : DAIMLERCHRYSLER CORPORATION
Service Bulletin Num : 1900805 Date of Bulletin: NOV 02, 2005
NHTSA Item Number: 10017651
Component: STEERING
Summary: REVISED POWER STEERING SYSTEM BLEEDING PROCEDURES. *SC
does this mean i can go into a dealership and have them fix my sunroof under warranty? I have about 50k on the odo and it's almost 4 yrs old....my sunroof only vents and doesn't open fully, thanks!
hemidakota said:
If it is a TSB or Recall then yes.
Incorrect....
A TSB is not like a recall in that regards. A TSB is not a warranty issue unless it remains under the factory warranty. In other words, at 50k, your sunroof issue is out of warranty.
A technical service bulletin is not an "open ticket" for a repair, and if you read it will actually say that right in the bulletin. The TSB is meant to give the technician information.
EVERY TSB said:
POLICY:
Reimbursable within the provisions of the warranty.
That being said... if it's a common issue, you "may" be able to get some assistance, but there is no addl. warranty available just because there is a bulletin. This is a very common misconception.
hemidakota said:
Thanks James...I stand corrected.
No problem!!! Just spreadin' the troof! :thumbsup:
1 - 17 of 17 Posts
