1 - 3 of 3 Posts
so i changed my alternator and my afr is at 16.5 at idle , but while cruising my afr is normal the car runs fine. before the alternator change the afr was at 14.7. so any suggestions on what it could be?
I removed the cat to get to the alternator
most likely an exhaust leak. did you replace the gasket on the down pipe when you put it back on?
agree.. if not that.. check for a vac leak
1 - 3 of 3 Posts
