Status
Not open for further replies.
1 - 1 of 1 Posts
This thread will go over the differences between the WMI kits we sell.
All AEM WMI kits are backed by a 1 year warranty.
30-3000 WMI Kit
This is our workhorse kit. It includes pretty much everything you need to get running and has a street price right around $400.
1 Gallon tank with integral level sensor
200 PSI Aquatec recirculating pump
Progressive pump controller with “Boost Safe” feature
Seamless integration with the AEM Injection Monitor, the ultimate WMI Failsafe & flow gauge
Custom injector body with integral 18 PSI checkvalve
3 jets included with each kit
20 feet of high pressure hose
Error protection output with over-current, over-voltage and over-temperature protection
System status LED indicator; shows pump duty cycle and system errors
Pump open and short detection and indication; works even if the pump is off
Test button that manually triggers pump
Two dial pump speed control
30-3001 WMI Kit
For those who want to go a bit bigger! Essentially the 1 gallon kit listed above but with a custom 5 gallon tank with integral baffle & level sensor and a second injector included. This one has a street price right around $500.
5 gallon tank with anti-slosh feature integral baffle & level sensor (Dimensions: 21"L x 8"W x 10"H)
Two custom injector bodies with integral 18 PSI checkvalves
30-3002 WMI Kit
A tankless kit for those who want to use an existing tank. Street price on this is in the low $340 range.
1 - 1 of 1 Posts
Status
