ok today I washed my car and cleaned the engine a little bit then i leave the car wash and then my abs light comes on so i drive a little bit it shuts off for like 5mins then came back on and been on since.
try unplugging ur battery to reset the pcm see if it goes away may be leaving it on if u took some tight turns or maybe something wrong with it? mine came on after some really fast and hard turning lol but then went off gl man
you did'nt get water in your engine comp. did ya??
im not part of the NE crew but...i had the same problem with mine, checked my brake fluid and refilled it and it hasnt come on again. $5 fix...i would fill that up and then go from there...
hrmm i'll have to check the brake fluid then....
I did wash my engine bay too.. whats the premise behind that?
