Hey SRT peeps! Newb here so I'm coming to best for help.
I just recently bought a CSRT4 from a friend it has 104000 on it. He was the origanl owner and from what I know he took great care of it... It had sat for some time in the driveway but is in good shape still so I jump at the opportunity to get it.
There are however some minor issues... I ran a scanner and received the following codes:u1110, u1120, u0121, u0416. I had a friend run them through tech connect and it saying something about non-commination with abs control module and recommend replacing it.
My symptoms are (lights) brake, abs, esp/bas, traction, engine. The Speedo intermittently works and the cruise doesn't work also the antilock brakes are disengaged.
So here is something weird. The red brake light some times goes off, Speedo comes back and I can turn the traction and cruise back on. While this happens the care runs smoothly however when the red brake light comes back on I get this wierd miss...? That's the best way to describe it, I'll be driving then it will have a hiccup. Sometimes frequently and sometimes less frequent.
Anyways I wanted to get your opinions on this may someone else has had this and can point me in a direction of remedy.
Thanks for reading this long unorganized and probably confusing post ? looking forward to hearing from you your thoughts.
