1 - 20 of 26 Posts
I just installed K&N CAI today, it makes great sounds, now my engine sings I love it. However, I found out the lowest point of the filter is only about 6 inches above the ground. I really doubt it can run through some wet grounds.. cos water may get splashed into the filter...
I am not sure how deep do you guys *think* it's a safe range of water depth? I dont wanna end up with a wet engine one day :(
Thanks!
superstrongbeast said:
correct... i got rid of myn for a mopar cai that comes with a splash gaurd
splash gaurd... sounds interesting. do you mind if you can take a picture of it? probably i will make one myself.. :p
or you can discribe me how it's like... which part of filter it protects?
Discussion Starter #6
Can anyone still answer what's the safe range of water depth I should go with?
Even K&N has hydro-blocked not only one engine, but I do see many people are still using it.
Look up the splash guard that PTPerformance makes. Very reasonable price and well built. I think they run in the ballpark of around 24.95ish. Correct me if I'm wrong. Definitely need one of these if you run the K&N especially.
Every puddle is different depending on the speed at which you hit it at and what not. I have heard of only a few inches of water that has done damage to motors. You just have to be careful. Look into getting a splash guard. They are an essential item if you run a CAI and especially if you are running the K&N
Discussion Starter #9 (Edited)
been running my K&N for almost 2 years with no problems...just have to be careful and make sure your not dipping the front end in water...though NJ is pretty flat for the most part and we dont get huge ammounts of rain usually...can still be cut down or made into short ram though if your dont feel like its safe
No
ac_srt4 said:
Also here, I wanna know how do you guys think about bypass valve? Does it really works?
link: http://www.autosportz.com/airintake_aem_bypassvalves.htm
Sorry I didn't find the splash guard there.. >< that will be great if someone can pass me a link.
You CANNOT use a bypass valve on a Turbo motor________5TOEZ_________& that "shield" everybodys tellin ya about, is NOT a sure thing.........if you submerge the filter area,in a deep enough puddle, no shield in the world will stop hydrolock, aka: a blown engine.
Why can't you use a bypass valve on a turbo motor?
Discussion Starter #13
that makes sense. how bypass valve works is, when water is being sucked from filter, u can then consider the filter is blocked. the engine will suck air from by passvalve then reduce the change of getting hydroblocked.
but a turbo charged engine will produce a low pressure area (almost vacuum) in the tube, when filter is suddenly blocked, i guess too little air can be sucked in from bypass valve, then the engine will run TOO lean thus blow it out..
Discussion Starter #14
hey i got one more question, i guess when i have the CAI on, i wont be able to do those automatic under car wash anymore right? (those drive thru under car wash with engine on)
Who fed you that line of crap?
Discussion Starter #18
then please explain why turbo charged engine shouldn't use bypass valve
Get the PTP splash guard and don't swamp boat race your Neon. If you're that worried about it then but the stock airbox in. Period.
1 - 20 of 26 Posts
